jwestmoreland wrote on Tuesday, October 09, 2007:
Richard,
I looked at http://www.freertos.org/History.txt but didn’t see any mention of the TCB changes from v4.4.0 to v4.5.0 - can
you please elaborate on the changes:
v4.4.0:
* Task control block. A task control block (TCB) is allocated to each task,
* and stores the context of the task.
typedef struct tskTaskControlBlock
volatile portSTACK_TYPE *pxTopOfStack; /*< Points to the location of the last item placed on the tasks stack. THIS MUST BE THE FIRST MEMBER OF THE STRUCT. */
unsigned portBASE_TYPE uxTCBNumber; /*< This is used for tracing the scheduler and making debugging easier only. */
xListItem xGenericListItem; /*< List item used to place the TCB in ready and blocked queues. */
xListItem xEventListItem; /*< List item used to place the TCB in event lists. */
unsigned portBASE_TYPE uxPriority; /*< The priority of the task where 0 is the lowest priority. */
portSTACK_TYPE *pxStack; /*< Points to the start of the stack. */
signed portCHAR pcTaskName[ configMAX_TASK_NAME_LEN ];/*< Descriptive name given to the task when created. Facilitates debugging only. */
unsigned portSHORT usStackDepth; /*< Total depth of the stack (when empty). This is defined as the number of variables the stack can hold, not the number of bytes. */
} tskTCB;
/*lint -e956 */
tskTCB * volatile data pxCurrentTCB = NULL;
v4.5.0:
#if ( configUSE_TRACE_FACILITY == 1 )
#if ( configUSE_MUTEXES == 1 )
unsigned portBASE_TYPE uxBasePriority;
} tskTCB;
/*lint -e956 */
tskTCB * volatile pxCurrentTCB = NULL;
Thanks,
John W.
