bennertz wrote on Wednesday, November 03, 2010:
I’m stuck with version 3.2.0 of FreeRTOS in some ancient code and updating to a newer version is not really an option, unfortunately. My platform is an ARM7 controller (STR710). The compiler tool chain I use is YAGARTO.
I would like to use the feature vTaskPrioritySet() when evolving the code but found a notice in the http://www.freertos.org/History.txt for the change from version 4.0.4 to version 4.0.5:
Bug fix: The ‘value’ of the event list item is updated when the priority of a task is changed. Previously only the priority of the TCB itself was changed.
Can anyone help me with the following questions:
Does this fix affect a bug that was present in version 3.2.0 already?
If so, are there any details on this issue still available (old ticket or such)? What would the effect of that bug be?
Thank you for all and any help,
Bernhard
