My timer settings are correct (SYSCLK set to 720000000 & Timer prescaler set to 71).
I find a huge 100us variable delay between the ISR END Function & my task resume. I don’t understand why, any answers ?
Please tell me if you need other informations
Thank’s
What else is your system doing? Does it have any critical sections that will delay the timer interrupt? Which chip are you using? not that it would make much difference to the jitter - you would be better off using a direct to task notification rather than a semaphore.
I work on a STM32F103ZDT6. I have around 15 Tasks working together without any critical sections.
I did some tests using only one test task and for a delay of 100us i achieve a real delay of 120us.
I currently work with FreeRTOS 7.0 & Tasks Notifications are not available under this version. But i think i will need to upgrade my firmware …
Version 7 is very old. The newer the version the more assert points there are to help you identify issues the first time you run the code.
Is the 120us period consistent? What period do you get if you setup the timer interrupt from main() then sit in a loop (in main(), so without making any FreeRTOS API calls)?
