I was looking for the default value for configTASK_NOTIFICATION_ARRAY_ENTRIES because it was not defined in the freeRTOSConfig.h file, but could not find any documentation about it. But I found it on another site’s forum.
Did I miss it?
If not then perhaps it would be useful to have a page where all the default values are listed. Especially those that are not by default defined.
Alternatively, it could be just mentioned (for all similar cases) wherever such configuration values are explained. Mentioning that if it is not defined then the value is x.
That is unless that is always the case… i.e. every configuration value that is not defined is always 1. But even then it would be good to list it for newbies like me.
Thank you
