First note: I have experienced this same issue on a windows host with a separate STM32 project. This leads me to believe it could be an issue with the way STM32Cube exports a project? or something related to the project setup.
Yes, If I run the program normally or in debug the LED toggles as expected. When I place the breakpoint on the toggle, it hits the breakpoint as expected, but when i continue, the LED dow not toggle, and its as if the program is just stuck on that breakpoint.
I am using OpenOCD and GDB with a makefile. my .cfg file is as follows:
source [find interface/stlink-v2-1.cfg]
transport select hla_swd
source [find target/stm32f7x.cfg]
reset_config srst_only
launch.json as follows:
"name": "Cortex Debug",
"type": "cortex-debug",
"cwd": "${workspaceRoot}",
"servertype": "openocd",
"executable": "${workspaceRoot}/build/F7_Template.elf",
"request": "launch",
"rtos":"FreeRTOS",
"device": "STM32F746ZG",
"configFiles": [
"./board.cfg"
I’ve added the OpenOCD FreeRTOS Helper file, and I added --undefined=uxTopUsedPriority to the LD flags.
my task is simply:
for(;;)
vTaskDelay(1000 / portTICK_PERIOD_MS);
HAL_GPIO_TogglePin(LD2_GPIO_Port, LD2_Pin);
I also see the same problem if i use OpenOCD and GDB without the Cortex-Debug plugin.
