I can’t debug application based on freertos on ti lm3s6965 using gdb and segger J-link.
I am using the linker file come in the demo application (standalone.ld)
the application work in run mode but at debugging it go into wrong address and don’t stop at main.
Sorry - I can only directly support code that has originated from Real Time Engineers Ltd. In this case however it sounds like you have a build setup problem, rather than a FreeRTOS problem.
