After creation of a task or queue with createstatic, I verify my heap free space but I found that it still the same as I define it in freertosconfig.h ?
I’m using heap 1 and I set the static allocation to 1 and freertos v 9.00
So could you tell me where those tasks are created exacetly ?
If you use the ‘CreateStatic’ version then you are explicitly using
statically allocated memory, by which I mean, memory allocated by the
compiler at compile time. That is distinct from dynamically allocated
memory, which is allocated from the heap at run time.
