I am new to FreeRTOS and have been learning using the debug demo project included in Dave Lyneham’s rtos.zip which was referenced in the x86 write up (http://www.freertos.org/portternee.html).
In main() I created 3 tasks, Each task does a forever loop incrementing a counter variable and then SLEEP_MS(1000). This code works if the 3 tasks have the same priority. But when I change each task’s priority (for example task 1 has priority 1, task 2 has priority 0, and task 3 has priority 2) then the application crashes when vTaskStartScheduler is called.
freertosconfig.h has #define configUSE_PREEMPTION 0
The controller board is Tern’s B engine with 512 MB SDRAM.
Paradigm C++ V7.00.0054, Tern Edition is the development tool.
The memory model is large.
I would prefer to use preemption but it crashes even when the priorities are identical. Is there something I have to do in addition to the freertosconfig.h #define change?
Hmm. That is very old code, not an official zip file (provided by Dave), and probably uses a very old version of FreeRTOS. I’m afraid there is not much help I can provide in this case.
If you are looking to learn and experiment with FreeRTOS in a convenient environment then you could try using the MSVC project with the Win32 simulator demos, or the Keil simulator demo.
I have switched to the demo project WizNET_DEMO_TERN_186 for the Tern B Engine 186. I have still encountered task / priority issues with this demo (I am using the Paradigm C/C++ IDE version 7.00 for Tern).
Since I did not have all of the hardware used in this project I commented out the serial and http task creates. I also modified 186.cfg (changed the amount of RAM from 128 to 512, the rdonly map from 0x0800 to 0x7ffff to 0x2c000 to 0x7ffff and the CODE_START from 0x0800 to 0x2c000) and freertosconfig.h (config_USE_IDLE_HOOK from 1 to 0 configCPU_CLOCK_HZ from 80000000 to 40000000).
After downloading the application I set breakpoints inside the various forever loops that are in the created tasks. When I executed the code none of the breakpoints were hit. I did this because an earlier debug session with a breakpoint in the prvCheckTask function in main.c showed that no other task was running so I thought I could confirm this by breakpoints in the forever loops.
What could be causing the lack of task execution other than prvCheckTask (I even changed its priority from tskIDLE_PRIORITY + 4 to tskIDLE_PRIORITY + 2)?
