I want to use a counting semaphore using direct to task notifications in this scenario:
I have a counting process and I want to be notified (the receiver task is woken up) every n items exactly and exclusively, I don’t want to be notified every item (the receiver task is is woken up whenever a single item is detected).
The examples given here, as far as I understood (or I misunderstood) count on every single item, so the system doesn’t miss any of them.
Is there a way to be notified only when exactly n items were detected using direct to task notifications, or do I need to use the semaphore primitives instead?
Thank you!
