sahilkhan wrote on Thursday, January 31, 2019:
I am working on TI CortexM4 microcontroller running FreeRTOS. I am trying to toggle a pin on microcontroller. I have noticed the GPIO port is toggling at very slow speed of 3.9usec, while the micrcontroller is running at 120MHz.
I have tried the same code without FreeRTOS and the toggling becomes very fast i.e. 150nsec.
My project has no interrupts running and here is the code i am running under FreeRTOS;
Please note, I have removed the hash sign infront of includes files as the posting system of sourceforge some how doesnt like it.
include <stdint.h>
include <stdbool.h>
include “main.h”
include “drivers/pinout.h”
include “utils/uartstdio.h”
// TivaWare includes
include “driverlib/sysctl.h”
include “driverlib/debug.h”
include “driverlib/rom.h”
include “driverlib/rom_map.h”
include “driverlib/gpio.h”
include “driverlib/inc/hw_memmap.h”
// FreeRTOS includes
include “FreeRTOSConfig.h”
include “FreeRTOS.h”
include “task.h”
include “queue.h”
define SYSTEM_CLOCK 120000000U
// Demo Task declarations
void demoLEDTask(void *pvParameters);
void demoSerialTask(void *pvParameters);
// Main function
int main(void)
// Initialize system clock to 120 MHz
uint32_t output_clock_rate_hz;
output_clock_rate_hz = ROM_SysCtlClockFreqSet(
(SYSCTL_XTAL_25MHZ | SYSCTL_OSC_MAIN |
SYSCTL_USE_PLL | SYSCTL_CFG_VCO_480),
SYSTEM_CLOCK);
ASSERT(output_clock_rate_hz == SYSTEM_CLOCK);
// Initialize the GPIO pins for the Launchpad
PinoutSet(false, false);
ROM_GPIOPinTypeGPIOOutput(GPIO_PORTM_BASE, GPIO_PIN_4 | GPIO_PIN_5 );
GPIOPadConfigSet(GPIO_PORTM_BASE, GPIO_PIN_4 | GPIO_PIN_5, GPIO_STRENGTH_2MA, GPIO_PIN_TYPE_STD);
// Create demo tasks
xTaskCreate(demoLEDTask, (const portCHAR *)"LEDs",
configMINIMAL_STACK_SIZE, NULL, 2, NULL);
xTaskCreate(demoSerialTask, (const portCHAR *)"Serial",
configMINIMAL_STACK_SIZE, NULL, 1, NULL);
vTaskStartScheduler();
return 0;
// Flash the LEDs on the launchpad
for (;;)
GPIOPinWrite(GPIO_PORTM_BASE,GPIO_PIN_4 |GPIO_PIN_5 ,0);
//for(i=0;i<1;i++){}
//SysCtlDelay(1);
GPIOPinWrite(GPIO_PORTM_BASE, GPIO_PIN_4 | GPIO_PIN_5, GPIO_PIN_4 | GPIO_PIN_5);
// Write text over the Stellaris debug interface UART port
// Set up the UART which is connected to the virtual COM port
UARTStdioConfig(0, 57600, SYSTEM_CLOCK);
for (;;)
UARTprintf("\r\nHello, world from FreeRTOS 9.0!");
vTaskDelay(5000 / portTICK_PERIOD_MS);
/* ASSERT() Error function
- failed ASSERTS() from driverlib/debug.h are executed in this function
void error(char *pcFilename, uint32_t ui32Line)
// Place a breakpoint here to capture errors until logging routine is finished
while (1)
And here is the scope snapshot
