I would like to use the MPU on a STM32H743. As I saw in the app notes, the MPU has some default regions, that are active if the MPU is actually turned off.
If I use FreeRTOS MPU port, do I need to re-create these default settings using explicit MPU regions?
Or will this set of defaults always be “in the background”?
If I’m reading the document correctly, the default map is only active when the MPU is off.
So if I enable the MPU, I suspect I have to explicitly program the RAM cache regions, device memory attributes, etc. ?
The MPU document you have linked above seems to set only the read/write attributes, but not the cache bits (of course it’s written for a Cortex-M3, so that’s ok).
So what about Cortex-M7 chips with more complex MPUs?
I’m not sure if this addresses / answers your concern/question, but I believe that:
When the MPU is enabled, if MPU_CTRL[PRIVDEFENA] is set to 1, any access to an address that is not in a defined MPU region acts as though it is going through the default map.
When the MPU is enabled and MPU_CTRL[PRIVDEFENA] is set to 0, any access to an address that is not in a defined MPU region results in a fault (processor exception)
If the MPU is not enabled, of course the default map is what’s used.
