dumarjo wrote on Wednesday, November 06, 2013:
I see in the source that the cortex-M3 MPU is supported. Is there a M4 MPU too ?
I don’t see anything about the M4
Regards
Jonathan
Regards
Jonathan
rtel wrote on Wednesday, November 06, 2013:
There is no specific M4 version of the MPU code, but there are few differences between the M3 and M4 code so just creating one using the M3 version as a starting point would not be tricky.
If you M4 does not have an FPU, or you leave the FPU switched off, then you can use the M3 port anyway.
Hi Richard,
M3 version as a starting point would not be tricky.If you M4 does not have an FPU, or you leave the FPU switched off,
I use the FPU too. I would take a look at the M3 port vs the M4 port and
give it a try !
regards
Jonathan
hawk777 wrote on Thursday, November 07, 2013:
A diff between CM3 and CM4F is very very small, and I expect will apply quite easily to the CM3MPU tree (don’t try it the other way). That’s what I plan to do to use FreeRTOS, until an official release for CM4FMPU shows up (if it does).
dumarjo wrote on Thursday, November 07, 2013:
I just found a sample of code in the interactive forum. I have adapted
it to the 7.5.3 (original was for 7.4.0). I will test it today. If it
work, I will try to generate patches and send it to Richard.
Regards
Jonathan
Cortex-M4 MPU support
https://sourceforge.net/p/freertos/discussion/382005/thread/31cba9a5/?limit=25#182e
Sent from sourceforge.net because you indicated interest in
SourceForge.net: Log In to SourceForge.netTo unsubscribe from further messages, please visit
SourceForge.net: Log In to SourceForge.net–
This message has been scanned for viruses and
dangerous content by MailScanner http://www.mailscanner.info/, and is
believed to be clean.
dumarjo wrote on Friday, November 08, 2013:
I did the merge and everything seem to work.
I have a quastion about the mpu. I hope someone here can give me some hint.
I have setup 2 tasks in user mode. As soon as I do a malloc like this.
char *p = (char *)pvPortMalloc(256);
p[0] = 0x55; <---- trig the memmanage fault.
If my tasks are in priveleged mode, no probleme at all.
From what I understand, the full RAM is supposed to be accible in R/W
by default. I have tweak my linker script based on the demos.
It it normal ?
Jonathan
then you can use the M3 port anyway.Regards.
https://sourceforge.net/p/freertos/discussion/382005/thread/31cba9a5/?limit=50#d7b4
rtel wrote on Friday, November 08, 2013:
By default, and unprivileged task only has access to its own stack, and nothing else. If you want it to access other RAM you have to explicitly tell the kernel it is ok. This can be done at the point the task is created, and then changed at run time.
I was confused then. I see in the port.c in fonction
vPortStoreTaskMPUSettings
if( xRegions == NULL )
/* No MPU regions are specified so allow access to all RAM. */
xMPUSettings->xRegion[ 0 ].ulRegionBaseAddress =
( ( unsigned long ) __SRAM_segment_start__ ) | /* Base
address. */
( portMPU_REGION_VALID ) |
( portSTACK_REGION );
xMPUSettings->xRegion[ 0 ].ulRegionAttribute =
( portMPU_REGION_READ_WRITE ) |
( portMPU_REGION_CACHEABLE_BUFFERABLE ) |
( prvGetMPURegionSizeSetting( ( unsigned long )
SRAM_segment_end - ( unsigned long ) SRAM_segment_start ) ) |
( portMPU_REGION_ENABLE );
I thought that the full RAM was accessible.
Regards
Jonathan
task is created, and then changed at run time.FreeRTOS-MPU, a FreeRTOS with memory protection support
FreeRTOS-MPU, a FreeRTOS with memory protection supportRegards.
How do you handle dynamic memory allocation in a RTOS system with the
MPU enabled ?
Regards
Jonathan
dumarjo wrote on Friday, November 22, 2013:
Hi Richard,
I have read gain and again on the MPU And I have a question about the
Port (for the M3). I see in the fonction prvSetupMPU, that you have
anabled the Privielege Background with
/* Enable the MPU with the background region configured. */
*portMPU_CTRL |= ( portMPU_ENABLE | portMPU_BACKGROUND_ENABLE );
I wonder why you define explicitely privilege region for the kernel ?
Should this be done directly by the portMPU_BACKGROUND_ENABLE ?
In a big application, How do you share Queue Handle, Mutex, etc… ?
Regards
Jonathan
https://sourceforge.net/p/freertos/discussion/382005/thread/31cba9a5/?limit=50#127c
rtel wrote on Friday, November 22, 2013:
To be honest, I can’t remember, it was a while ago it was developed. What happens if you turn the background region off?
Well I would like to test the opposit. I think we should use the
background to privileged mode and not define the 2 region (flash and
ram) privileged. Then this should give 2 more region to the task.
I try to do that but I got a problem in the context switch. Since we
have more region, I think we chould change something in the
contextswitch. Probably around those line
" ldr r1, [r3] \n"
" ldr r0, [r1] \n" /* The first item
in the TCB is the task top of stack. /
" add r1, r1, #4 \n" / Move onto the
second item in the TCB… /
" ldr r2, =0xe000ed9c \n" / Region Base
Address register. /
" ldmia r1!, {r4-r11} \n" / Read 4 sets
of MPU registers. /
" stmia r2!, {r4-r11} \n" / Write 4 sets
of MPU registers. */
I’m not sure to understand this correctly.
Those instruction read 4 region from the xMPU_SETTINGS xMPUSettings;
and write thoses to 0xe000ed9c ?
Regards
Jonathan
https://sourceforge.net/p/freertos/discussion/382005/thread/31cba9a5/?limit=25#fd56
