Cortex-M MPU ports delay high priority ISRs
The documentation says that interrupts above configMAX_SYSCALL_INTERRUPT_PRIORITY are not delayed by the kernel. (Among other places, in the FreeRTOS customization page’s configKERNEL_INTERRUPT_PRIORITY section: “Interrupts with priority above configMAX_SYSCALL_INTERRUPT_PRIORITY are never delayed by the RTOS kernel activity.”
However, the Cortex-M MPU ports don’t meet that promise as of kernel 11.3.0. xPortStartScheduler() writes SHPR2 = 0, making SVCall the highest-priority exception in the system. With the v2 MPU wrappers, every FreeRTOS API call made by an unprivileged task enters and exits the kernel through SVC. While those handlers run at priority 0, every interrupt is blocked — including application interrupts above configMAX_SYSCALL_INTERRUPT_PRIORITY whose timing the kernel promises not to affect.
I was able to fix this on my system (STM32H7A3, Cortex-M7 r1p1 @ 280 MHz, GCC, mpu_wrappers_v2, 16 MPU regions, all tasks unprivileged, 4 priority bits,configMAX_SYSCALL_INTERRUPT_PRIORITY at NVIC level 5, configSVCALL_INTERRUPT_PRIORITY at level 4) by making the SVCall priority configurable: a new configSVCALL_INTERRUPT_PRIORITY, written to SHPR2 in place of the hardcoded 0. I placed this below my time-critical ISR band, so that those ISRs now preempt SVC dispatch. The SVCall priority has to be numerically lower than configMAX_SYSCALL_INTERRUPT_PRIORITY so that the scheduler startup works.
I’m curious to see what everyone thinks of this and if I’ve missed anything.
Hi @dbrunner4 and welcome to the forum.
I think you are right. This discussion from a few years ago went a little too fast, and a contributor who shall remain nameless later made this commit which changed the setting in SHPR2. I like that the commit moved the setting to a more logical place, but I don’t like that it is set to zero. It should probably be set to the original value:
#define portNVIC_SVC_PRI ( ( ( uint32_t ) configMAX_SYSCALL_INTERRUPT_PRIORITY - 1UL ) << 24UL
I’d be glad to submit the PR if it helps, but I can’t get to it until Monday. Alternatively, you could submit the PR if you want to.
Thank you @jefftenney! Please raise the PR.
Just closing the loop here. PR #1470 was merged. It restores the original behavior for ARMv7-M MPU ports from before v11.0.0. Specifically, it reduces the SVC priority from 0 (the maximum priority) back to configMAX_SYSCALL_INTERRUPT_PRIORITY - 1.
A separate PR (#1481) is under consideration to apply a similar improvement to the ARMv8-M ports. The ARMv8-M ports have used SVC priority 0 (the maximum priority) from the beginning.
