So finally, FreeRTOS plus TCP+IP is working with vivado and zynqboard.
My question is regarding setup in case of e.g. two zynqboards connected via ethernet.
Network interface is initialized. If i connect zynqboad1 to windows, ping+data exchange working. If i connect zynqboard2 to windows, ping+data exchange working. If i connect zynqboard1 to zynqboard2 with lwIP, ping and dataexchange are working. But if i connect zynqboard1 to zynqboard2 via TCPIP, ping works (if arp request send before ping) but the connect function fails with error code -128(pdFREERTOS_ERRNO_ENOTCONN). Is there any special settings has to be done to connect two zynqboards with tcpipstack via tcp socket?
zynqboard1 is server, zynqboard2 is client.
zynqboard1: not use gateway, not use dhcp, ip is set to 192.0.0.3, subnet mask is ffffff00, mac is 0x11 0x22 0x33 0x44 0x55 0x77.
zynqboard2: not use gateway, not use dhcp, ip is set to 192.0.0.4, subnet mask is ffffff00, mac is 0x11, 0x66, 0x33, 0x44, 0x55, 0x88.
Connection between the 2 boards was made with:
-patch cable directly, patch cable through switch, patch cable through hub
-crosslink cable directly, crosslink cable through switch(its obviously the same as pacth cable directly), crosslink cable through hub.
May I ask if there any options to be set in case of direct eth connection between two zynqboards with freeRTOS+TCPIP?
I tried to reproduce the issue locally on 2 STM32 device connected via ethernet cable and the TCP connection worked fine for me. I was able to send and receiver data between the server and client.
It would be great if you can share how you are configuring the client and server on the device to look further into the issue.
Some moments please something is started to working, im targeting two question now:
-some mac addresses not working, some yes
We changed the mac addresses and since a point it started to work. We changed nothing, but the mac addresses. We used like: 0x11 0x22 0x33 0x44 0x55… etc and on the other side 0x66 0x55 0x44… Then started to get random addresses and it seems to work.
Generally if you have assigned mac address to your hardware which accidentally matches existing connected device mac address there might be issue with the connection.
Most of the time we take MAC of any device and change the last few bytes of the address to assign it to the hardware.
The second bit of the MAC address (counted from MSB) indicates a locally administrated address. For the sake of it, try using ox26… instead of 0x66… to see if some component in your setup gets confused by that bit set.
