vyacheslavz wrote on Sunday, December 20, 2009:
I run into bazaar problem - once I setup configUSE_TRACE_FACILITY to 0 on SAM7, FreeRTOS stopped working:
Steps:
Take ARM7_AT91SAM7X256_Eclipse, stripped it by removing the demo task, web server, and uip - still works
My FreeRTOS config ia as follows:
#define configUSE_IDLE_HOOK 0
#define configUSE_TICK_HOOK 1
#define configCPU_CLOCK_HZ ( ( unsigned long ) 47923200 )
#define configTICK_RATE_HZ ( ( portTickType ) 1000 )
#define configMAX_PRIORITIES ( ( unsigned portBASE_TYPE ) 4 )
#define configMINIMAL_STACK_SIZE ( ( unsigned short ) 200 )
#define configTOTAL_HEAP_SIZE ( ( size_t ) ( 24 * 1024 ) )
#define configMAX_TASK_NAME_LEN ( 0)
#define configUSE_MUTEXES 1
/* Co-routine definitions. */
#define configMAX_CO_ROUTINE_PRIORITIES ( 2 )
#define INCLUDE_vTaskPrioritySet 0
#define INCLUDE_uxTaskPriorityGet 0
#define INCLUDE_vTaskDelete 0
#define INCLUDE_vTaskCleanUpResources 0
#define INCLUDE_vTaskSuspend 0
#define INCLUDE_vTaskDelayUntil 1
#define INCLUDE_vTaskDelay 1
#define INCLUDE_xTaskGetCurrentTaskHandle 0
#define INCLUDE_vTaskList 0
As soon as I change configUSE_TRACE_FACILITY to 0, the image size is 8.2 K (great), but free rtos stoped working.
As far as I can see from debugging, it does not gets ticks interrupts?
Any ideas how to solve this?
On the alternative, any working starting point for FReeRTOS+GCC+SAM7?
