Configurable RISC-V chip extensions
I’d like feedback on an idea related to the RISCV chip extensions before I create a pull request.
I think it would be good to add a FREERTOS_RISC_EXTENSION option to the CMake project similar to how FREERTOS_PORT is used. The CMake project would issue an error and provide valid options if the user chooses a RISC_V port but does not specify a chip extension folder name. Currently, the chip extension support is quite limited, and doesn’t support all the chip extensions available for GCC.
What do maintainers think about this idea?
Hi Joe,
Thank you for your idea. I think user who uses RISC-V port with CMake can benefit from this. We would like discuss with you in the pull request if you want to create a pull request for this idea.
