freertos90 wrote on Friday, April 14, 2017:
Hello;
My portmacro.h file include this function
Description Resource Path Location Type
'configMAX_SYSCALL_INTERRUPT_PRIORITY' undeclared (first use in this function) portmacro.h /osiloskop/src line 139 C/C++ Problem
On the other hand my freertosconfig.h does not include this function FreertosConfig.h is include this:
#define configMAX_API_CALL_INTERRUPT_PRIORITY 18
#define configCPU_CLOCK_HZ 100000000UL
#define configUSE_PORT_OPTIMISED_TASK_SELECTION 1
#define configUSE_TICKLESS_IDLE 0
#define configTICK_RATE_HZ ( ( TickType_t ) 1000 )
#define configPERIPHERAL_CLOCK_HZ ( 33333000UL )
#define configUSE_IDLE_HOOK 1
#define configUSE_TICK_HOOK 1
#define configMAX_PRIORITIES ( 7 )
#define configMINIMAL_STACK_SIZE ( ( unsigned short ) 200 )
#define configTOTAL_HEAP_SIZE ( 80 * 1024 )
#define configMAX_TASK_NAME_LEN ( 10 )
#define configUSE_MUTEXES 1
#define configQUEUE_REGISTRY_SIZE 8
#define configUSE_RECURSIVE_MUTEXES 1
#define configUSE_MALLOC_FAILED_HOOK 1
#define configUSE_APPLICATION_TASK_TAG 0
#define configUSE_COUNTING_SEMAPHORES 1
#define configUSE_QUEUE_SETS 1
/* Co-routine definitions. */
#define configMAX_CO_ROUTINE_PRIORITIES ( 2 )
/* Software timer definitions. */
#define configUSE_TIMERS 1
#define configTIMER_TASK_PRIORITY ( configMAX_PRIORITIES - 1 )
#define configTIMER_QUEUE_LENGTH 5
#define configTIMER_TASK_STACK_DEPTH ( configMINIMAL_STACK_SIZE * 2 )
#define INCLUDE_vTaskPrioritySet 1
#define INCLUDE_uxTaskPriorityGet 1
#define INCLUDE_vTaskDelete 1
#define INCLUDE_vTaskCleanUpResources 1
#define INCLUDE_vTaskDelayUntil 1
#define INCLUDE_vTaskDelay 1
#define INCLUDE_xTimerPendFunctionCall 1
#define INCLUDE_eTaskGetState 1
/* This demo makes use of one or more example stats formatting functions. These
format the raw data provided by the uxTaskGetSystemState() function in to human
readable ASCII form. See the notes in the implementation of vTaskList() within
FreeRTOS/Source/tasks.c for limitations. */
#define configUSE_STATS_FORMATTING_FUNCTIONS 1
/* The private watchdog is used to generate run time stats. */
#include "xscuwdt.h"
extern XScuWdt xWatchDogInstance;
extern void vInitialiseTimerForRunTimeStats( void );
#define configGENERATE_RUN_TIME_STATS 1
#define portCONFIGURE_TIMER_FOR_RUN_TIME_STATS() vInitialiseTimerForRunTimeStats()
#define portGET_RUN_TIME_COUNTER_VALUE() ( ( 0xffffffffUL - XScuWdt_ReadReg( xWatchDogInstance.Config.BaseAddr, XSCUWDT_COUNTER_OFFSET ) ) >> 1 )
/* The size of the global output buffer that is available for use when there
are multiple command interpreters running at once (for example, one on a UART
and one on TCP/IP). This is done to prevent an output buffer being defined by
each implementation - which would waste RAM. In this case, there is only one
command interpreter running. */
#define configCOMMAND_INT_MAX_OUTPUT_SIZE 2096
/* Normal assert() semantics without relying on the provision of an assert.h
header file. */
void vAssertCalled( const char * pcFile, unsigned long ulLine );
#define configASSERT( x ) if( ( x ) == 0 ) vAssertCalled( __FILE__, __LINE__ );
/* If configTASK_RETURN_ADDRESS is not defined then a task that attempts to
return from its implementing function will end up in a "task exit error"
function - which contains a call to configASSERT(). However this can give GCC
some problems when it tries to unwind the stack, as the exit error function has
nothing to return to. To avoid this define configTASK_RETURN_ADDRESS to 0. */
#define configTASK_RETURN_ADDRESS NULL
/****** Hardware specific settings. *******************************************/
* The application must provide a function that configures a peripheral to
* create the FreeRTOS tick interrupt, then define configSETUP_TICK_INTERRUPT()
* in FreeRTOSConfig.h to call the function. This file contains a function
* that is suitable for use on the Zynq MPU. FreeRTOS_Tick_Handler() must
* be installed as the peripheral's interrupt handler.
void vConfigureTickInterrupt( void );
#define configSETUP_TICK_INTERRUPT() vConfigureTickInterrupt()
void vClearTickInterrupt( void );
#define configCLEAR_TICK_INTERRUPT() vClearTickInterrupt()
/* The following constant describe the hardware, and are correct for the
Zynq MPU. */
#define configINTERRUPT_CONTROLLER_BASE_ADDRESS ( XPAR_PS7_SCUGIC_0_DIST_BASEADDR )
#define configINTERRUPT_CONTROLLER_CPU_INTERFACE_OFFSET ( -0xf00 )
#define configUNIQUE_INTERRUPT_PRIORITIES 32
/****** Network configuration settings - only used when the lwIP example is
built. See the page that documents this demo on the http://www.FreeRTOS.org
website for more information. ***********************************************/
/* The priority for the task that unblocked by the MAC interrupt to process
received packets. */
#define configMAC_INPUT_TASK_PRIORITY ( configMAX_PRIORITIES - 1 )
/* The priority of the task that runs the lwIP stack. */
#define configLWIP_TASK_PRIORITY ( configMAX_PRIORITIES - 2 )
/* The priority of the task that uses lwIP sockets to provide a simple command
line interface. */
#define configCLI_TASK_PRIORITY ( tskIDLE_PRIORITY )
/* MAC address configuration. */
#define configMAC_ADDR0 0x00
#define configMAC_ADDR1 0x13
#define configMAC_ADDR2 0x14
#define configMAC_ADDR3 0x15
#define configMAC_ADDR4 0x15
#define configMAC_ADDR5 0x16
/* IP address configuration. */
#define configIP_ADDR0 172
#define configIP_ADDR1 25
#define configIP_ADDR2 218
#define configIP_ADDR3 200
/* Netmask configuration. */
#define configNET_MASK0 255
#define configNET_MASK1 255
#define configNET_MASK2 255
#define configNET_MASK3 0
so I have this error:
My file version are same (8.2.1)
