Eugene
(Eugene)
June 26, 2020, 12:53pm
1
Hi !
I have tried to compile LPC55S69 port when on nonsecure part rtos used without any secure context allocation. E.g- configENABLE_TRUSTZONE == 0
But in portasm this flag is not used and xSecureContext is still referenced.
portasm.c:232: undefined reference to `xSecureContext’
Is any idea how to disable this in correct way ?
Regards,
Eugene
aggarg
(Gaurav Aggarwal)
June 26, 2020, 2:52pm
2
Eugene
(Eugene)
June 26, 2020, 5:53pm
3
Hi Gaurav !
Looks like feature is not fully supported under #ifdef configENABLE_TRUSTZONE flag.
I should take other portasm.c from different folder.
Basically it mean RTOS what is running on nonsecure side without any communication with secure side.
Is this so ?
Regards,
Eugene
aggarg
(Gaurav Aggarwal)
June 26, 2020, 6:06pm
4
If you do not want to use TrustZone support (i.e. want to have the complete memory space as non-secure), you need to do the following two things:
Build FreeRTOS with configENABLE_TRUSTZONE set to zero in FreeRTOSConfig.h file.
Use ARM_CM23_NTZ or ARM_CM33_NTZ port files depending on whether the target hardware is an ARM Cortex-M23 or an ARM Cortex-M33.
As I mentioned above, it is described in detail here: Using FreeRTOS on ARMv8-M Microcontrollers - FreeRTOS
Is this so ?
Yes.
