I’m using FreeRTOS v11.0.1 on an STM32H7 microcontroller with the CMSIS-RTOS2 abstraction layer (cmsis_os2.h). During development, I encountered a configASSERT() failure in port.c, specifically at this line:
configASSERT((portNVIC_INT_CTRL_REG & portVECTACTIVE_MASK) == 0);
This occurred when calling osMessageQueueGetSpace() from within an interrupt context (e.g., inside HAL_UART_RxCpltCallback()).
Upon investigation, I found that osMessageQueueGetSpace() internally calls uxQueueSpacesAvailable(), which is no longer safe to call from ISR context in FreeRTOS v11 due to the added assert above.
I initially tried replacing it with:
UBaseType_t space = uxQueueGetQueueLength(queue) - uxQueueMessagesWaiting(queue);
However, both uxQueueGetQueueLength() and uxQueueMessagesWaiting() also trigger the same assert in ISR context in v11.
Eventually, the problem was resolved by switching to:
UBaseType_t waiting = uxQueueMessagesWaitingFromISR(queue);
UBaseType_t length = uxQueueGetQueueLength(queue);
Since there’s no public API to get the queue length from a QueueHandle_t in ISR-safe manner, the length must be tracked manually or defined as a macro.
Suggestion:
It might be helpful if osMessageQueueGetSpace() internally detects ISR context and uses uxQueueMessagesWaitingFromISR() when appropriate, to maintain CMSIS compatibility with FreeRTOS v11.
Has anyone else encountered this? Is there a plan to adjust the CMSIS layer accordingly for FreeRTOS v11?
Thanks in advance!
