crippler1 wrote on Tuesday, March 10, 2015:
Hi
I have a problem,
my config assert pops at configASSERT( pxEnd ) in pvPortMalloc function, when I try to create task
it means that pxEnd is not initialized.
any suggestions?
Hi
I have a problem,
any suggestions?
andymcc0 wrote on Tuesday, March 10, 2015:
Does this provide a clue?
void *pvPortMalloc( size_t xWantedSize )
BlockLink_t *pxBlock, *pxPreviousBlock, *pxNewBlockLink;
void *pvReturn = NULL;
/* The heap must be initialised before the first call to
prvPortMalloc(). */
configASSERT( pxEnd );
i.e. have you called vPortDefineHeapRegions() ?
Do you need heap_5.c with its segmented, user defined heap?
at the heap5.c pxEnd = NULL at declaration as static.
I don’t see any change at pxEnd to any non zero value, at the all file.
as for the heap5 question
I am new to free rtos and i wrote simple main func that creates a task and runs it.
rtel wrote on Tuesday, March 10, 2015:
Andy made some suggestions as to what the problem might be, but I don’t think you have answered either of his questions.
I see that vPortDefineHeapRegions() contains the same assert check,
but I don’t see the code that change the pxEnd before the assert check.
Actually, it doesn’t. It checks pxEnd is NULL to ensure you don’t call
the function twice.
It is done in vPortDefineHeapRegions().
Where is it done?
Didn’t I tell you that in my very last post in this thread?
Sorry for the dumb question:
should I use heap for every program that I write?
I have watch some tutorials for free RTOS, and I never saw heap functions at main.
