nobody wrote on Tuesday, July 19, 2005:
I have Cygwin installed on the windows syste.
GCC version I have is:
gcc (GCC) 3.3.3 (cygwin special)
Copyright (C) 2003 Free Software Foundation, Inc.
This is free software; see the source for copying conditions.  There is NO
warranty; not even for MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE.
When I run make or ram_ram.bat, I get the following errors:
arm-elf-gcc -c -Wall -D  -D GCC_AT91FR40008 -I. -I…/…/Source/include -I…/Common/include  -mcpu=arm7tdmi -T -Wcast-align  …/…/Source/portable/GCC/ARM7_AT91FR40008/portISR.c -o …/…/Source/portable/GCC/ARM7_AT91FR40008/portISR.o
arm-elf-gcc: cannot specify -o with -c or -S and multiple compilations
make: *** […/…/Source/portable/GCC/ARM7_AT91FR40008/portISR.o] Error 1
With ./ram_arm.bat
c:\freertos-1\FreeRTOS\Demo\ARM7_AT91FR40008_GCC>set USE_THUMB_MODE=NO
c:\freertos-1\FreeRTOS\Demo\ARM7_AT91FR40008_GCC>set DEBUG=-g
c:\freertos-1\FreeRTOS\Demo\ARM7_AT91FR40008_GCC>set OPTIM=-O0
c:\freertos-1\FreeRTOS\Demo\ARM7_AT91FR40008_GCC>set RUN_MODE=RUN_FROM_RAM
c:\freertos-1\FreeRTOS\Demo\ARM7_AT91FR40008_GCC>set LDSCRIPT=atmel-ram.ld
c:\freertos-1\FreeRTOS\Demo\ARM7_AT91FR40008_GCC>make
arm-elf-gcc -c -Wall -D RUN_FROM_RAM -D GCC_AT91FR40008 -I. -I…/…/Source/include -I…/Common/include -g -mcpu=arm7tdmi -Tatmel-ram.ld -Wcast-align -O0 …/…/Source/portable/GCC/ARM7_AT91FR40008/portISR.c -o …/…/Source/portable/GCC/ARM7_AT91FR40008/portISR.o
/ecos-c/DOCUME~1/Owner/LOCALS~1/Temp/ccIEhNNj.s: Assembler messages:
/ecos-c/DOCUME~1/Owner/LOCALS~1/Temp/ccIEhNNj.s:38: Error: literal referenced across section boundary (Implicit dump?)
/ecos-c/DOCUME~1/Owner/LOCALS~1/Temp/ccIEhNNj.s:87: Error: literal referenced across section boundary (Implicit dump?)
/ecos-c/DOCUME~1/Owner/LOCALS~1/Temp/ccIEhNNj.s:103: Error: literal referenced across section boundary (Implicit dump?)
Any suggestions as to what needs to be done to get it going. Is it gcc version or something else that is causing it to not compile?
Thanks and regards
B
