I get the compiler error:
Error: missing expression - `swi’ in queue.c at the line(s) taskYIELD. I am using RTOS 6.0.1 for the ARM7 in the GCC version. However I tried a 5.x queue.c file with the same result. Additionally I generated a list file of queue. c that has the following appearence:
485:C:/ARM7Programme/workspace/RTOS/rtos/source\queue.c **** taskYIELD
So in principle the replacement of taskYIELD() to SWI seems OK. So my guess is more of an assembler syntax problem. I also tried the different portmacro.h versions for the ARM7 that are available without any success.
I am using the gcc version 4.4.2 and assembler 2.2.
Latest GCC & binutils requires that every SWI instruction should be followed by number which is passed to called software exception. Before tools assumed that the lack of this number means 0. So add 0 to SWI and it should compile/work.
