So i have used Freertos timers before, and in this project i have used 3 freertos timer. it was running smoothly earlier. but ad task increased i have notice the code gets hang at
For troubleshooting i disabled one freertos timer but than it started Hanging at assert for another timer. this is timer related issue but i am unable to pinpoint what is causing it?
Timer task Stack depth is 256
Timer task priority is 3
Timer queue length is 10
Is the code actually stuck on the configASSERT() statement? A very common implementation of configASSERT() is to loop forever so that a developer can identify a problem and inspect the cause.
I’m assuming you found that xResult is zero after the call the xTimerGenericCommand(). And I’m also assuming your configASSERT() is defined to loop forever and do nothing when an assertion fails. Will you please use a debugger to verify these two assumptions?
Assuming the above, the timer command queue is likely full. Can you try increasing the queue length from 10 to 15?
