Is there an eval. version of Code Composer Essentials? I could take a stab at it. I ported FreeRTOS over to the MSP430 using IAR - so it may be even a closer port if you’re using the MSP430.
Yes this port is for the MSP430f1611 and there is a free version of code composer with an 8kb limitiation. There is also a $20 package that includes a USB based eval board that doubles as a programing pod for the 14pin parts. I dont know if there is sufficient ram for these smaller parts or not to support the RTOS on the $20 system.
Before you try to use the port - please read the notes.txt file posted - it’s on my homepage.
Note that I only have the 8KB demo. version of CCE from TI - allegedly it is the latest release - just limited to 8KB. Due to this - I was only able to enable the LED task in the demo. I used the 'U64 board that comes with the USB FET if you order it that way. Again, take a look at the port notes. I’ve been running the LED demo (with IDLE task, of course) for a couple of days now - and it has been running OK.
I also used the default workspace location in CCE, so you can unzip the file there or you can move around as you see fit.
Oh, I almost forgot to mention this - you need to manually move some of the obj’s into their locations when you build. I don’t know why CCE is doing this at this point - but heap_2.obj needs to be moved into it’s location (the linker will tell you) and all of the objs that are built in msp430f1611 need to be moved there (again - the linker will complain) - you’ll see the objs in the project - you just need to move them…
