The x86 port of FreeRTOS is just for real mode operation. Unless you have a very old version of VC++ I don’t think you can generate 16bit consolte apps with it. A protected mode port would be a very different. If you do have a copy that will generate 16bit apps then very few changes should be required. Let me know if this is the case.
I’m beginner and have trouble to run and simulate the free rtos 7.0 that i’ve downloaded . I confuse how to setup for Visual C++ Express Edition 2008 and Watcom 1.8. Any one could help ? Thx
If you want to use VS and not GCC, then use the 2010 Express Edition. It is free to download and use. Then you won’t need to set up anything, just open the Demo\WIN32-MSVC\Win32.sln solution file from in the VS tool (or double click the solution file to have it start VS automatically).
