Freertos CMSIS v2 (STM32 Cube IDE)timer problem
When I use an infinite loop in any task, the timer is blocked (the Callback function is not called). Other tasks run normally.
Test program:
DefaultTask: toggle LED1
Task01: blinking LED2
Task02: blinking LED3
CallbackTimer01: blinking LED timer
when used in DefaultTask:
while(!HAL_GPIO_ReadPin(GPIOB,GPIO_PIN_13));
LED1 toggle on signal from input
LED2 is blinking
LED3 is blinking
The LED timer does not blink
//toggle LED1
void DefaultTask(void *argument)
for(;;)
while(!HAL_GPIO_ReadPin(GPIOB,GPIO_PIN_13));//{osDelay(1);}
HAL_GPIO_TogglePin(GPIOC,GPIO_PIN_15);
//blnking LED2
void Task01(void *argument)
int timer;
for(;;)
osDelay(1);
if(++timer>200){timer=0;HAL_GPIO_TogglePin(GPIOB,GPIO_PIN_14);}
//blinking LED3
void Task02(void *argument)
int timer;
for(;;)
osDelay(1);
if(++timer>200){timer=0;HAL_GPIO_TogglePin(GPIOB,GPIO_PIN_13);}
//blinking LED timer
int timer;
void CallbackTimer01(void *argument)
if(++timer>50){timer=0;HAL_GPIO_TogglePin(GPIOA,GPIO_PIN_0);}
When I put in the infinite loop osDelay(1);
while(!HAL_GPIO_ReadPin(GPIOB,GPIO_PIN_13)){osDelay(1);}
LED timer flashes - Timer calls the callback function.
Is this normal behavior?
