I’ve successfully built the “Webserver demo” under IAR EWARM 6.5. As per the README file, I have been able to remove unwanted code (USB, ENET) and rebuilt the code without warning or error.
Now I want to start adding my code in. First, I create a group called “Drivers” and include the appropriate CMSIS driver source files and their include paths. I also add the file “system_LPC17xx.c”. I then do a build without warnings or errors.
I then add the include file “debugf_frmwrk.h” into the “main.c” file. I then get multiple repeats of this error:
Error: identifier “LPC_UART_TypeDef” is undefined C:\Users\grr\Documents\IAR Embedded Workbench\arm\examples\NXP\LPC17xx\LPC1700CMSIS\Drivers\include\lpc17xx_uart.h 578
Which demo? Where did you get the project from?
Without wanting to state the obvious, it looks like a header file that defines LPC_UART_TypeDef is not included where it should be. Is LPC17xx_uart.h included from a FreeRTOS file? If so then there must be a header file that needs including before it.
Another thought, I’m not familiar with the NXP libraries but some libraries from other manufactures have a config file that you need to set to say which peripherals to include and which to exclude. Maybe UART is excluded from the build?
Thanks for the input. I had 2 lpc17xx.h header files; I’ve fixed that and a few other things. it now compiles and just about runs.
I have posted a new question on this issue.
