I am using the latest CM33 gcc port (portable\GCC\ARM_CM33_NTZ\non_secure) and saw that they do not check the interrupt priorities. All other Cortex-M ports check them using the configMAX_SYSCALL_INTERRUPT_PRIORITY and provide the function vPortValidateInterruptPriority() used in the macro portASSERT_IF_INTERRUPT_PRIORITY_INVALID(). However, this macro is empty in all CM33 ports. In my opinion, this check is also necessary for the CM33. Is that a bug or omitted on purpose?
Thank you,
Peter
Thank you for this clarification. I think it is important because I tracked down a sporadic bug in my application, where a task object was corrupted. The reason for that was my own ISR running at priority 0 and calling a FreeRTOS ISR function, which is not allowed at priority 0. With the check mentioned above, an assertion would have failed.
The master copy of those port layers is here if you would like to add the code and create a pull request to get the change upstreamed. I think the code can be copied from the ARMv7-M version.
