I see the latest release of the FreeRTOS-kernel is 11.0.1 as per:
However, for some reason, when I clone via command line or even browsing directly on GitHub.com I seem to get 10.4.4 when checking task.h file.
To get the latest I have to click the release and download the zip from there.
Any ideas of why this is?
Yeah, this is most likely my git knowledge that is lacking, or almost none existent.
But if the main branch is a development branch, then cloning the tag instead sounds reasonable to me. Because a straight clone of the main branch gives me the 10.4.4 thing.
However, that gives me
fatal: ‘origin/V11.0.1’ is not a commit and a branch ‘V11.0.1’ cannot be created from it
fatal: unable to checkout submodule ‘FreeRTOS-Kernel’
The idea was just to add kernel as a submodule to my project, but my knowledge with is lacking
I normally use Tortoise git which has a simple interface and integrates into Windows, only dropping to the command line for more complex actions…however I just tried:
and see DEVELOPMENT BRANCH in the file header comments. I then entered the FreeRTOS kernel directory and typed:
git checkout V11.0.1
Just to try the simplest command. I then received the V11.0.1 files - so this seemed to work (although it is more likely you want to create a local branch using something like:
After some trial and error I was able to get it to work with the help of your tips.
To add it as a submodule this is what needed to be done:
git submodule add https://github.com/FreeRTOS/FreeRTOS-Kernel.git <path of the submodule>
git submodule update --init
BUT!
This pulls in 10.4.4 for a reason I’m not sure of.
To get it up to latest, at time of writing it is V11.0.1 release.
Inside the submodule directory, do:
So then there was just a typo inside the task.h file?
BTW, I see that I messed up my quote in my post above this. Not all syntax is in the quote, unfortunately I am not able to edit this now. But if someone with permission can, it would be great.
Might help someone later on
