Hallo!
I am trying to implement a command line interface using the libraries provided in FreeRTOS. I managed to run with the UDP connection, however I encounter two bugs when implementing the same functionality with a TCP:
- the first is that the TCP connection stops working after 8 commands sent.
- the second is that no matter the pdFALSE value only one line gets printed out over the TCP. If a command returns more lines, only the first one gets printed out.
None of these bugs were present when using UDP. I tried separating the ‘listening’ and ‘respond’ functionality in separate tasks, but it does not solve the problem.
I am using lwIP stack for the network communication.
Does anybody have an idea why the task freezes after 8 commands have been recieved? Or maybe even how to get more lines printed out? The tcp connection should still be active - there is a separate function to close a connection without deleting it. I am not using it here, so - as far I understand - I should be able to write() to the connection as long as it is up.
My code:
void vTCPCommandConsoleTask(void* pvParamaters){
struct netconn *pxNewConnection, *tcpconn;
struct netbuf *buf, *pxRxBuffer, *buf_send;
err_t connection_err, send_err, bind_err, listen_err, accept_err, recv_err;
ip_addr_t board_addr;
unsigned int payload_len;
char *data, *payload_data;
BaseType_t xMoreDataToFollow;
static signed char cOutputString[ configCOMMAND_INT_MAX_OUTPUT_SIZE ], cLocalBuffer[ configCOMMAND_INT_MAX_OUTPUT_SIZE ];
/* create a new connection */
tcpconn = netconn_new(NETCONN_TCP);
/* bind the connection to a local IP */
IP4_ADDR((&board_addr.u_addr.ip4), netif_cfg[0]->ip_addr[0], netif_cfg[0]->ip_addr[1], netif_cfg[0]->ip_addr[2], netif_cfg[0]->ip_addr[3]);
bind_err = netconn_bind(tcpconn, &board_addr, SRC_PORT_NUM );
/* start listening and accept */
if (bind_err== ERR_OK) {
listen_err = netconn_listen(tcpconn);
for( ;; ){
accept_err = netconn_accept(tcpconn, &pxNewConnection);
if(accept_err == ERR_OK){
/*recieve the packet */
recv_err = netconn_recv(pxNewConnection, &pxRxBuffer);
if ( recv_err == ERR_OK ){
/* Get the payload and length */
payload_len = pxRxBuffer->p->len;
payload_data = pxRxBuffer->p->payload;
/* Copy the recieved message into the command string */
signed char cInputString[payload_len];
strncpy(cInputString, payload_data, payload_len);
/* create new buffers and send them for each line of the output */
do{
/*Pass the string to FreeRTOS+CLI. */
xMoreDataToFollow = FreeRTOS_CLIProcessCommand( cInputString, cOutputString, configCOMMAND_INT_MAX_OUTPUT_SIZE );
/*create a buffer to send the data and fill it with output */
buf_send = netbuf_new();
data = netbuf_alloc(buf_send, sizeof(cOutputString));
memcpy(data, cOutputString, sizeof(cOutputString));
/* Send the output generated by the command's implementation. */
netconn_write( pxNewConnection, data , (u16_t) configCOMMAND_INT_MAX_OUTPUT_SIZE, NETCONN_COPY );
/* Free the buffer */
netbuf_delete(buf_send);
} while( xMoreDataToFollow != pdFALSE ); /* keep sending until the command does not generate any more output. */
} //rev_err == ERR_OK
} //accept_err
} //while(1)
} //bind_err
