I am using Free RTOS v7.02 and am relatively new to it. I am considering using a counting semaphore as a way of counting the number of interrupts that occur in a fixed period of time. However there is a chance that I cannot “take” all of the accumulated semaphore counts before a separate part of the program takes over. Is there a way to clear the accumulated counts? Deleting the semaphore would not work because a task will be blocked on it. I know that the queue management api has a “QueueReset” function but I could not find anything similar in the semaphore/mutex api.
You can pass your semaphore handle into the queue reset function. Just cast the xSemaphoreHandle to an xQueueHandle if the compiler generates a warning about the type mismatch.
However, xQueueReset() was only introduced in V7.1.1, and even then it will not let you reset a queue/semaphore when tasks are blocked on it. V7.2.0 will allow queues that have tasks blocked on them to be reset.
