autylocus wrote on Wednesday, June 02, 2010:
Does anyone know if there is an easy way to check whether code is currently being executed from a task or if it is running from an ISR? Is this going to be a device dependent? I’m not very familiar with FreeRTOS as a platform, is this even possible with the current framework? I’m currently using an NXP LPC17xx with FreeRTOS 6.0.4. Has anyone else run into this/has a solution?
