ktownsend wrote on Tuesday, January 06, 2009:
I’m just trying FreeRTOS out for the first time, and have made two tasks with different priority. As expected, the higher priority task executes 10 times, but when I adjust it’s priority to be lower (expecting the other task to kick in), everything seems to stop. The second tasks priority is higher than idle, so I don’t understand why this is happening? I get the same results if I delete the higher priortity task as well. Perhaps the problem is with the handlers?
If anyone has a moment to enlighted me, I’d appreciate it. (It would be great to see more code examples on the website, but beggers can’t be choosers I suppose.)
#include "lpc214x.h"
#include "FreeRTOS.h"
#include "task.h"
// Note: On ARM7 devices, you must be using Supervisor mode to run the scheduler with FreeRTOS.
// This can be set in Crossworks by adding "#define SUPERVISOR_START" to crt0.s
// Declare task handlers (used to reference a task when required)
xTaskHandle xFirstTaskHandle, xPriorityTaskHandle;
// Temp Fields
U8 counter = 0;
// First task code
static portTASK_FUNCTION (vFirstTask, pvParameters __attribute__ ((unused)))
for( ;; )
debug_printf("Executing First Task\n");
// Priority task code
static portTASK_FUNCTION (vPriorityTask, pvParameters __attribute__ ((unused)))
for( ;; )
debug_printf("Executing Priority Task\n");
counter++;
// If this task has been executed 10 times, reduce it’s priority
if (counter == 10)
counter = 0;
// Remove this task from the scheduler
// vTaskDelete(xPriorityTaskHandle);
// Lower this task’s priority
vTaskPrioritySet(xPriorityTaskHandle, tskIDLE_PRIORITY + 1);
int main(void)
xTaskCreate(vFirstTask, (const signed portCHAR * const) "FIRST", configMINIMAL_STACK_SIZE, NULL, (tskIDLE_PRIORITY + 2), &xFirstTaskHandle);
xTaskCreate(vPriorityTask, (const signed portCHAR * const) "PRIORITY", configMINIMAL_STACK_SIZE, NULL, (tskIDLE_PRIORITY + 3), &xPriorityTaskHandle);
// Start scheduler
vTaskStartScheduler ();
return 0;
