I am trying to put together the Cellular MQTT Demo and run it on a custom modem.
Modem has already been ported to Cellular Interface and I am trying to setup tls and mqtt on top of it.
When I look at the files used by the demo I see the mbedtls cellular wrapper is mentioned to be under ./FreeRTOS-Plus/Source/Utilities/mbedtls_freertos/mbedtls_bio_freertos_cellular.c
Readme.md file on that directory still mentions mbedtls folder so was that folder accidentally deleted?
Additionally, looking at the file from an older commit I see that mbedtls_cellular_send function uses Sockets_Send from sockets_wrapper.h interface. However, I don’t see where exactly Sockets_Send function is implemented to call Cellular Interface socket functions.
I understand grouping files by common folders for reuse but this makes it really hard to discover where files come from on a demo especially when documentation is not updated to match when folders change.
Where should I look at to find where exactly the cellular wrappers for mbedtls is for the demo and also where Sockets_Send function that uses the Cellular Interface is implemented.
Cellular interface implements the bottom layer sockets. You already port it to your platform.
Above the cellular interface, there is a TCP Sockets Wrapper. The purpose here is to abstract different network interface, for example the FreeRTOS+TCP. You will need the following files:
transport_mbedtls.c implements the following functions. These functions can be used in the demo application for transport interface implementation.
TLS_FreeRTOS_Connect
TLS_FreeRTOS_Disconnect
TLS_FreeRTOS_recv ( transport receive )
TLS_FreeRTOS_send ( transport send )
My suggestion is to reference any one of the cellular demo project under FreeRTOS_Cellular_Interface_Windows_Simulator. You can see which files are required for the transport interface implementation with cellular.
Thank you again for pointing out the document is out of sync. This is something we can improve.
Thank you so much for a detailed breakdown of the stack and also where to look for specific files.
I think I understand the layering much better now and I see why we need each file.
Can you explain when I would use mbed tls bio functions and why I would need them? A link to an explanation would also be appreciated if you have it handy. I just don’t know what exactly they do.
I saw the sln files for the demos but I am on a Linux machine.
I downloaded a vscode extension that opens sln files and displays them like a workspace and I can see all the files that are used. I won’t really be able to build or test the example since I don’t have access to one of the supported modems or a Windows machine but seeing where all the files come from is still quite beneficial.
I’ll make another post if I run into issues but this should get me starting so I appreciate the response.
Mbed TLS bio functions are the send\recv callbacks that are called within the Mbed TLS library. They are implemented with TCP_Sockets_Send and TCP_Sockets_Recv.
mbedtls_ssl_set_bio is the API to set bio callbacks for Mbed TLS library. It is called in TLS_FreeRTOS_Connect indirectly when performing the TLS handshaking.
