herschy wrote on Thursday, November 01, 2012:
Hi!
Currently working with CCS v5.1 compiling code for an ARM MCU LM3S1968 Cortex-M3 using tms470, v4.9.1.
For the time being, I am using FreeRTOS v6.0.5.
I am programming c++ and compiler options have been set to support “GCC extensions” and “C++ exception handling”.
My problem: catching an exception from within a running task when an object is throwing the exception
THIS WORKS:
having a try-catch inside my task and explicitly throwing an exception. The exception is caught in the exception handler as expected to. All well!
try{
throw 5;
catch(int& e)
//exception is caught
THIS DOES NOT WORK (for me):
when an object inside the try-block raises an exception it never gets caught.
Myclass my1;
try{
my1.MethodThrowsException();
catch(…) //regardless of what I put here
exception is never caught
Can anyone explain why? Is there a workaround?
Any help would be highly appreciated
