Hi
I am using freeRTOS 10.4.3 version with GCC version 9.3.1 and GCC version 10.3.1
In stream_buffer.c I get the following warning:
Cast increases required alignment of target type on the following line
prvInitialiseNewStreamBuffer( ( StreamBuffer_t * ) pucAllocatedMemory, /* Structure at the start of the allocated memory. */ /*lint !e9087 Safe cast as allocated memory is aligned. */ /*lint !e826 Area is not too small and alignment is guaranteed provided malloc() behaves as expected and returns aligned buffer. */
pucAllocatedMemory + sizeof( StreamBuffer_t ), /* Storage area follows. */ /*lint !e9016 Indexing past structure valid for uint8_t pointer, also storage area has no alignment requirement. */
xBufferSizeBytes,
xTriggerLevelBytes,
ucFlags );
Any Idea ?
