nobody wrote on Saturday, September 03, 2005:
When I remove the line that creates the USB task from the lwIP project - the next time I compile and run I get a data abort exception. How can not creating the USB task cause an exception?
rtel wrote on Saturday, September 03, 2005:
Have you removed the idle task hook that writes to the USB port? If you don’t initialise the USB port but try to write to it, it could well crash.
Remove the line
vUSBSendByte( cTxByte );
from the function
vApplicationIdleHook();
define in file
FreeRTOS/Demo/lwIP_Demo_Rowley_ARM7/main.c
