Following up on the excellent advice given to the article given by @Boudewijn.Dijkstra .
I decided to name as many objects as possible. I am however failing to see any ISRs showing up as actors. I have also noted some inconsistencies in the configuration files with the API.
In trcConfig.h i have set TRC_CFG_INCLUDE_ISR_TRACING to 1. In the comments above this define, there are mentioning of two functions, which do not exist in the codebase
xTraceStoreISRBegin and xTraceStoreISREnd
I think that is likley that its meant to say.
xTraceISRBegin and xTraceISREnd
However, even using these calls in the manner described in the comments for xTraceISRRegister does not show the ISR as an actor
These are the steps i have taken in order to use tracealyzer when i use a EXTI to detect that a microSD card beeing inserted in a slot.
Now, everything works and I can step through the code with a debugger probe, but nothing named micrSD_insert_ISR shows up in traceviewer when I look at it afterwards. (I have not yet added all ISRs)
It might be that the “entry table” in TraceRecorder is running out of slots. Try increasing TRC_CFG_ENTRY_SLOTS. See the Troubleshooting section in the guide you linked to. Does that help?
I defined TRC_CFG_USE_TRACE_ASSERT to 1 in the bottom of trcConfig. This got me a number of interesting things to fix.
I have configNUM_THREAD_LOCAL_STORAGE_POINTERS set to 0, which it did not like.
However, this seems to have been related to me enabling TRC_CFG_ENABLE_TASK_MONITOR in an attempt to track down the problem in the first place. So I defined TRC_CFG_ENABLE_TASK_MONITOR to 0 again.
I also had set TRC_CFG_ENTRY_SYMBOL_MAX_LENGTH to 50 apparently, which it also did not like. I caught an assert that said that 28 was the max value. It might be good to mention it in the config file.
Following up on “naming as many items as possible” I noticed that I had named the NMI interrupt, and it had worked flawlessly. However I have also recently added -Wconversion to my GCC options and it triggered on my call to enable TraceRecorder for the NMI ISR as the priority of the NMI interrupt is -2 and xTraceISRRegister function requires the priority to be uint32_t.
Should these ISRs not be traceable or should perhaps the parameter be changed to a signed type?
I am not sure that there is an issue. It may only be that I am misunderstanding the usage.
And as issue reporting is disabled for the TracerecorderSource repo, I thought that this might be a good forum for discussion as Perceoio staff are active here.
No, I let the it underflow and wrap around for now and thus leaving the warning active so that I don’t miss this in the future when this has been in someway investigated by Percepio.
NMIs cannot be traced (reliably) since they can interrupt all other trace event writing at any time, resulting in corrupt trace data. I would not recommend that you do that all the time. (you might get lucky every now and then so if you are looking for something specific in your NMI then it can be worth a shot to try it).
As the NMI only triggers in rather severe error events, I dont really expect the system to “survive” such an event without the watchdog rebooting the system. I only want to be able to record the event in a best effort way in order to do a post mortem analysis afterwards.
