amalo wrote on Friday, June 12, 2009:
Hi, I am having a little problem. I reduced my code to a really simple example. I cannot create more then 5 task (excluding IDLE).
When I put on more, I think there is memory corruption and that interupt call a function that does not exist (use an invalid function pointer…)
Any hints on that behavior?
here is my code:
#include "FreeRTOS.h"
#include "task.h"
#include "BSP_WDOG_API.h"
#include "Printf.h"
#define DBUG_TASK_STACK_SIZE configMINIMAL_STACK_SIZE + 200
#define DBUG_TASK_PRIORITY tskIDLE_PRIORITY + 2
void vDbugTask( void *pvParameters );
void vDbugTask2( void * pvParameters );
static volatile unsigned portLONG TestCounter = 0;
static volatile unsigned portLONG TestCounter2 = 0;
FUNCT:
int main(void)
char *str_running = "running from ??? ";
char *str_Flash_0 = "running from Flash 0 ";
char *str_Flash_A = "running from Flash A ";
char *str_Flash_B = "running from Flash B ";
char *str_SRAM = "running from Int SRAM ";
char *str_SDRAM = "running from Ext SDRAM ";
xTaskHandle thDebug;
xTaskHandle thDebug2;
static unsigned char ucParamDebug;
// Point to string
if(__RUNNING_FROM == __FLASH_RUNNING_0) str_running= str_Flash_0;
if(__RUNNING_FROM == __FLASH_RUNNING_A) str_running= str_Flash_A;
if(__RUNNING_FROM == __FLASH_RUNNING_B) str_running= str_Flash_B;
if(__RUNNING_FROM == __SRAM_RUNNING) str_running= str_SRAM;
if(__RUNNING_FROM == __SDRAM_RUNNING) str_running= str_SDRAM;
// Start Message
printf("\n======== MCF5282: %s ========\n", str_running );
// Init Timer
Timer_init( );
//WDog_init(FALSE, 0);
/* Start debug task */
xTaskCreate( vDbugTask, ( signed portCHAR * ) "DEBUG", DBUG_TASK_STACK_SIZE, &ucParamDebug, DBUG_TASK_PRIORITY, &thDebug );
xTaskCreate( vDbugTask2, ( signed portCHAR * ) "DEBUG2", DBUG_TASK_STACK_SIZE, &ucParamDebug, DBUG_TASK_PRIORITY, &thDebug2 );
// Start the scheduler.
vTaskStartScheduler();
return 0;
FUNCT: vDbugTask
void vDbugTask( void * pvParameters )
portTickType xLastWakeTime;
const portTickType xFrequency = 200;
signed char pcWriteBuffer[200];
(void) pvParameters;
// Initialise the xLastWakeTime variable with the current time.
xLastWakeTime = xTaskGetTickCount();
for( ;; )
vTaskList(pcWriteBuffer );
printf("\n%s\n", "task name status priority HWMTS ID");
printf("%s\n", pcWriteBuffer );
printf("%d\n", TestCounter );
TestCounter++;
// Wait for the next cycle.
vTaskDelayUntil( &xLastWakeTime, xFrequency );
FUNCT: vDbugTask
portTickType xLastWakeTime2;
const portTickType xFrequency = 600;
xLastWakeTime2 = xTaskGetTickCount();
for( ;; )
TestCounter2++;
vTaskDelayUntil( &xLastWakeTime2, xFrequency );
FUNCT: vApplicationStackOverflowHook
void vApplicationStackOverflowHook( xTaskHandle *pxTask, signed portCHAR *pcTaskName )
/* This will get called if a stack overflow is detected during the context
switch. Set configCHECK_FOR_STACK_OVERFLOWS to 2 to also check for stack
problems within nested interrupts, but only do this for debug purposes as
it will increase the context switch time. */
( void ) pxTask;
( void ) pcTaskName;
for( ;; )
And my freeRTOS config:
FreeRTOS.org V5.1.1 - Copyright (C) 2003-2008 Richard Barry.
This file is part of the FreeRTOS.org distribution.
FreeRTOS.org is free software; you can redistribute it and/or modify
it under the terms of the GNU General Public License as published by
the Free Software Foundation; either version 2 of the License, or
(at your option) any later version.
FreeRTOS.org is distributed in the hope that it will be useful,
but WITHOUT ANY WARRANTY; without even the implied warranty of
MERCHANTABILITY or FITNESS FOR A PARTICULAR PURPOSE. See the
GNU General Public License for more details.
You should have received a copy of the GNU General Public License
along with FreeRTOS.org; if not, write to the Free Software
Foundation, Inc., 59 Temple Place, Suite 330, Boston, MA 02111-1307 USA
A special exception to the GPL can be applied should you wish to distribute
a combined work that includes FreeRTOS.org, without being obliged to provide
the source code for any proprietary components. See the licensing section
of http://www.FreeRTOS.org for full details of how and when the exception
can be applied.
* SAVE TIME AND MONEY! We can port FreeRTOS.org to your own hardware, *
* and even write all or part of your application on your behalf. *
* See http://www.OpenRTOS.com for details of the services we provide to *
* expedite your project. *
Please ensure to read the configuration and relevant port sections of the
online documentation.
http://www.FreeRTOS.org - Documentation, latest information, license and
contact details.
http://www.SafeRTOS.com - A version that is certified for use in safety
critical systems.
http://www.OpenRTOS.com - Commercial support, development, porting,
licensing and training services.
#ifndef FREERTOS_CONFIG_H
#define FREERTOS_CONFIG_H
#include "MCF5282.h"
* Application specific definitions.
* These definitions should be adjusted for your particular hardware and
* application requirements.
* THESE PARAMETERS ARE DESCRIBED WITHIN THE ‘CONFIGURATION’ SECTION OF THE
* FreeRTOS API DOCUMENTATION AVAILABLE ON THE FreeRTOS.org WEB SITE.
* See http://www.freertos.org/a00110.html.
#define configUSE_IDLE_HOOK 0
#define configUSE_TICK_HOOK 0
#define configCPU_CLOCK_HZ ( ( unsigned portLONG ) SYSTEM_CLOCK_HZ )
#define configTICK_RATE_HZ ( ( portTickType ) 100 )
#define configMINIMAL_STACK_SIZE ( ( unsigned portSHORT ) /*150*/300 )
#define configTOTAL_HEAP_SIZE ( ( size_t ) ( 18/*12*/*1024 ) )
#define configMAX_TASK_NAME_LEN ( 12 )
#define configUSE_MUTEXES 1
#define configCHECK_FOR_STACK_OVERFLOW 1
#define configUSE_RECURSIVE_MUTEXES 1
#define configQUEUE_REGISTRY_SIZE 10
#define configUSE_COUNTING_SEMAPHORES 0
#define configMAX_PRIORITIES ( ( unsigned portBASE_TYPE ) 6 )
#define configMAX_CO_ROUTINE_PRIORITIES ( 2 )
#define INCLUDE_vTaskPrioritySet 1
#define INCLUDE_uxTaskPriorityGet 1
#define INCLUDE_vTaskDelete 1
#define INCLUDE_vTaskCleanUpResources 0
#define INCLUDE_vTaskDelayUntil 1
#define INCLUDE_vTaskDelay 1
#define INCLUDE_uxTaskGetStackHighWaterMark 1
#define configYIELD_INTERRUPT_VECTOR 16UL
#define configKERNEL_INTERRUPT_PRIORITY 1
#define configMAX_SYSCALL_INTERRUPT_PRIORITY 4
void vApplicationSetupInterrupts( void );
Thanks!
