Cannot compile Xtensa port assembly with --text-section-literals
I could not compile the assembly source of Xtensa port with --text-section-literals. I read somewhere they say that I have to add .literal_position directive.
I fixed it in my own work. Could you please support these changes in the official repository?
Thanks,
Chi Tran
Hi, could you point out which repository you are using?
Additionally, do you have a patch with the changes you made to support this flag?
Thanks
Hi Archit,
I’m using the public github repository, branch main.
https://github.com/FreeRTOS/FreeRTOS-Kernel.git
My patch is following:
diff --git a/portable/ThirdParty/XCC/Xtensa/xtensa_context.S b/portable/ThirdParty/XCC/Xtensa/xtensa_context.S
index 55ce8e0..a6545b9 100644
--- a/portable/ThirdParty/XCC/Xtensa/xtensa_context.S
+++ b/portable/ThirdParty/XCC/Xtensa/xtensa_context.S
@@ -62,6 +62,7 @@ NOERROR: .error "C preprocessor needed for this file: make sure its filename\
     .text
+    .literal_position
diff --git a/portable/ThirdParty/XCC/Xtensa/xtensa_vectors.S b/portable/ThirdParty/XCC/Xtensa/xtensa_vectors.S
index bf5916c..6cb8f37 100644
--- a/portable/ThirdParty/XCC/Xtensa/xtensa_vectors.S
+++ b/portable/ThirdParty/XCC/Xtensa/xtensa_vectors.S
@@ -306,6 +306,7 @@
     .global     _xt_panic
     .type       _xt_panic,@function
     .align      4
+    .literal_position
 _xt_panic:
     #ifdef XT_SIMULATOR
@@ -386,6 +387,7 @@ Debug Exception.
     .section    .DebugExceptionVector.text, "ax"
     .global     _DebugExceptionVector
     .align      4
+    .literal_position
 _DebugExceptionVector:
@@ -424,6 +426,7 @@ Double exceptions are not a normal occurrence. They indicate a bug of some kind.
     .section    .DoubleExceptionVector.text, "ax"
     .global     _DoubleExceptionVector
     .align      4
+    .literal_position
 _DoubleExceptionVector:
@@ -447,6 +450,7 @@ Kernel Exception (including Level 1 Interrupt from kernel mode).
     .section    .KernelExceptionVector.text, "ax"
     .global     _KernelExceptionVector
     .align      4
+    .literal_position
 _KernelExceptionVector:
@@ -478,6 +482,7 @@ User Exception (including Level 1 Interrupt from user mode).
     .global     _UserExceptionVector
     .type       _UserExceptionVector,@function
     .align      4
+    .literal_position
 _UserExceptionVector:
@@ -1036,6 +1041,8 @@ _xt_lowint1:
     .global     _Level2Vector
     .type       _Level2Vector,@function
     .align      4
+    .literal_position
 _Level2Vector:
     wsr     a0, EXCSAVE_2                   /* preserve a0 */
     call0   _xt_medint2                     /* load interrupt handler */
@@ -1107,6 +1114,8 @@ _xt_medint2_exit:
     .global     _Level3Vector
     .type       _Level3Vector,@function
     .align      4
+    .literal_position
 _Level3Vector:
     wsr     a0, EXCSAVE_3                   /* preserve a0 */
     call0   _xt_medint3                     /* load interrupt handler */
@@ -1506,6 +1515,8 @@ _xt_highint3:
     .global     _Level4Vector
     .type       _Level4Vector,@function
     .align      4
+    .literal_position
 _Level4Vector:
     wsr     a0, EXCSAVE_4                   /* preserve a0 */
     call0   _xt_highint4                    /* load interrupt handler */
@@ -1546,6 +1557,8 @@ _xt_highint4:
     .global     _Level5Vector
     .type       _Level5Vector,@function
     .align      4
+    .literal_position
 _Level5Vector:
     wsr     a0, EXCSAVE_5                   /* preserve a0 */
     call0   _xt_highint5                    /* load interrupt handler */
@@ -1626,6 +1639,8 @@ _xt_highint6:
     .global     _NMIExceptionVector
     .type       _NMIExceptionVector,@function
     .align      4
+    .literal_position
 _NMIExceptionVector:
     wsr     a0, EXCSAVE + XCHAL_NMILEVEL  _ /* preserve a0 */
     call0   _xt_nmi                         /* load interrupt handler */
Chi
Hi, I put the patch in a PR here: Enable use of --text-section-literals in Xtensa port by archigup · Pull Request #485 · FreeRTOS/FreeRTOS-Kernel · GitHub
Thank you so much.
Chi
