But I do not want to trigger the task contains xQueueReceive () immediately(Event based task), but instead i want to make a periodic task that check the queue every specific period of time :
So for example if I made something like that:
task_10ms()
TickType_t xLastWakeTime;
const TickType_t xPeriod = pdMS_TO_TICKS(_10_MS_);
xLastWakeTime = xTaskGetTickCount();
for (;;)
while ( xQueueReceive(xCanRxQueue, &can_frame, 0) != errQUEUE_EMPTY)
// Read data that can_frame points to
vTaskDelayUntil(&xLastWakeTime, xPeriod);
My question is that CAN interrupt could come in very short time (ex: 1ms), So in that case does the queue will keeping updated while task10_ms executed ? OR Kernel suspend interrupts until task finished ?
And if queue could be updated while i am reading it, Do i need to set this task in critical section till i finish reading ?
The Queue logic will handle the needed Critical Section in the access of the data in the queue, so you don’t need to. As long as the task can process the messages fast enough to keep the queue from filling, you should be ok.
Thank you for your response.
From what you say, the queue will handle the critical section but then processing queue by the task (code inside the while loop) can be interrupted normally. So If I want to secure the task as much as possible , is it a good idea to create critical section while processing ? Or is there other better solutions ?
What do you mean or what do you want to achieve be secure the task ?
Note that critical sections are intended to protect very short pieces of (non-blocking) code because they’re implemented by disabling all FreeRTOS covered interrupts.
My point is that i want to execute while loop in specific time. So if for example when while loop started to serve queue, there were 10 messages in the queue. Then I want to insure that i will only serve these 10 messages only and not get interrupt in between that will increase the queue with new message. I am not sure if that scenario could happen or not, That is why I am asking about that.
