I’m running FreeRTOS ver 9.0.0 on Cortex-M4 (MK20DX256) and I’ve recently run into an issue with the MCU freezing completely while running FreeRTOS. Although I haven’t managed to replicate the case again, I’m taking precautionary measures so it doesn’t repeat again - hopefully we’ll figure out why it froze in the first place.
I’m curious if the cause of crash/freeze could have anything to do with calling vTaskDelay() or any other FreeRTOS function from a function outside the task esp if that function happens to be in a different cpp file e.g.
Hi AbdulSamad , you should investigate what the “freezing” is. Could there be an exception, that ends in an eternal loop for(;;)?
Does your function digitalRead() always succeed? Or does it wait for a condition that sometimes does not occur?
It should not make any difference in which source file a function is located.
Are you using C++ ? That should work OK with FreeRTOS, as long as the compiler knows the linkage type of every function ( C versus C++ ).
C-only headers will often include these statements:
#ifdef __cplusplus
extern "C" {
/* Put your C declarations here */
#ifdef __cplusplus
Mind you that constructors of global and static C++ objects, are being called before main() is active. If you use the option nostartfiles, you will have to call the constructors your self. Also make sure that in these constructors, you can not use many resources: for instance the heap has not been set-up yet before main() is running.
The code that you’re showing is simple and looks good to me.
Yes, I’m using C++. The code in the example above constitutes a small chunk of the functionalities in the original application and I thought it would be most suitable for elaboration purposes.
Good pointers! I’ve come across such cases before and to avoid them, I’ve added a good amount of precautionary measures as follows:
all tasks have while(true) or for( ; ; ) loops
all tasks defined as static
no while(true) or for( ; ; ) loop exists without vTaskDelay()
software doesn’t try to access invalid memory e.g. task handles, and semaphores
no unsupported blocking function is called e.g. Arduino’s delay()
semaphores are accessed only when available
after deleting tasks, assign their task handles to NULL and call vTaskDelay()
I’ll look into the C-only headers and double check the library if the expressions need to be added.
Do you mind elaborating on this part please?
class CMyClass {
uint8_t *pcBuffer;
public:
CMyClass();
~CMyClass();
CMyClass::CMyClass()
// main() might not be running yet
pcBuffer = pvPortMalloc( BUFFER_SIZE );
CMyClass::~CMyClass()
// This might never get called
vPortFree( pcBuffer );
// Constructor will be called *before* main is active.
// Destructor will be called *after* main has exit,
// which never happens
CMyClass globalObject;
int main()
// Initialise hardware.
// Initialise heap.
// Here OK : heap has been initialised
// The destructor is never called because
// vTaskStartScheduler() never returns
CMyClass autoObject;
// Start scheduler.
vTaskStartScheduler();
