I’m a tad confused abt. the usTaskCheckFreeStackSpace() function in task.c. Allow me to quote it in full (sry 'bout that) from the provided source code:
Now, on a PIC32 MCU portSTACK_GROWTH is = -4, i.e. every iteration in the while() loop will increase the tested address by 4 – looks very much like we’re counting 32-bit integers, doesn’t it?
However, on exiting the while() loop the count of 32-bit integers in usCount is divided by sizeof(portSTACK_TYPE)!
In the PIC32 port, sizeof(portSTACK_TYPE) is = 4. In other words, I end up with a stack high water mark that is 4 TIMES TOO SMALL. This is borne out by setting a breakpoint in usTaskCheckFreeStackSpace() and just doing a memory dump of the memory being scanned.
Am I missing something really silly here, or is this a bona fide bug?
While you’re at it can you confirm (or dis-) that the various forms of the macro taskCHECK_FOR_STACK_OVERFLOW() in task.c will in fact detect a stack *underflow* when portSTACK_GROWTH > 0? Granted, not that I know about a whole lot of CPU:s where the stack grows “upwards”.
As per your original question - the current SVN version handles cases where the stack grows up from low memory (portSTACK_GROWTH > 0), but the current release version doesn’t.
