I was interested in having a play with FreeRTOS+POSIX. I have downloaded the labs today where I was expecting to find the code. However the version downloaded seems identical to the version of labs I had previously downloaded and only contains
Ah - seems we need to make this much clearer :o) The download links are
embedded in the instructions for running the example project: https://www.freertos.org/FreeRTOS-Plus/FreeRTOS_Plus_POSIX/demo/posix_demo.html
When building for Linux you just download a single file (I think?) as
the example uses the POSIX interface exposed by Linux, when then running
in the FreeRTOS Windows port you download a visual studio project that
has the same example AND the FreeRTOS+POSIX code. Sorry for the confusion.
ok thanks. This explains it, I had looked at the single file linux example but not realised that I need to download the windos example to get at FreeRTOS+POSIX.
