nobody wrote on Monday, January 15, 2007:
How can I port it to a new cpu?
rtel wrote on Monday, January 15, 2007:
The easiest way to run co-routines is in the idle task. If the scheduler is running then a full port is required to swap the idle task in and out. However, if you know that only co-routines are ever going to be created and never any other tasks then you could ignore the context saving and restoring and just write a normal interrupt for the tick. This should in theory make for a very simple port and system but I have never tried it
Thank you Richard.
