I have a use case where there are multiple tasks each of which have one queue where they are pushing results. I want to have a single task running processing elements from all of these queues. My plan was to have the single processing task use a Queue Set to monitor the multiple client queues.
Here is my question: If the Queue Set currently contains 2 queues and the processing task is blocked from calling XQueueSelectFromSet, is it safe for another thread to call XQueueAddToSet to add another queue to watch? And furthermore, assuming that the previous operation is safe, will adding an element to the queue which was just added to the Queue Set unblock the task that called XQueueSelectFromSet prior to the new queue being added into the set?
