I’m pulling down the FreeRTOS+TCP source code using SVN on a case insensitive file system, and I noticed that in the following folder there are multiple copies of winbase.h
and windows.h
(one set with lower case w’s and one with capitol W’s):
https://github.com/FreeRTOS/FreeRTOS-Plus-TCP.git/trunk/test/build-combination/Common
All 4 files appear to be empty, and because there are duplicate files that differ only by case my file system can’t have both exist at the same time so I get continuous messages from SVN that the capitol ‘W’ versions of each are missing.
This doesn’t really break anything, it is just annoying.
PS>> I have also noticed that the file ff_locking.org.c
in the FreeRTOS+FAT repo also seems redundant, and will cause issues if you try to tell a compiler to compile all .c files in the folder since it has conflicting definitions for the functions in ff_locking.c
https://github.com/FreeRTOS/Lab-Project-FreeRTOS-FAT.git/trunk
