Could you please help on this.
Using:
STM32CubeIDE
Platform MCU
Try the same using the native API, and if it doesn’t work, post the code here so I can try it.
Hi, this below code not working.
Could you try from your end please.
void oneShotCallback( TimerHandle_t pxTimer )
int main(void)
#if 1
TimerHandle_t onShotTimer = NULL;
onShotTimer = xTimerCreate( "oneShotTimer", (5000 / portTICK_PERIOD_MS), pdFALSE, 0, oneShotCallback );
if( onShotTimer == NULL )
// The timer was not created.
if( xTimerStart( onShotTimer, 0 ) != pdPASS )
// The timer could not be set into the Active state.
/* Init scheduler */
osKernelInitialize();
osKernelStart();
while (1)
/* USER CODE END 3 */
I just tried the following code, which printed out “5000” as expected:
printf( "%d", ( int ) xTaskGetTickCount() );
int notmain( void )
#if 1
onShotTimer = xTimerCreate( "oneShotTimer", ( 5000 / portTICK_PERIOD_MS ), pdFALSE, 0, oneShotCallback );
for( ;; );
for( ;; );
//osKernelInitialize();
//osKernelStart();
vTaskStartScheduler();
while( 1 )
Can you check the tick interrupt is executing properly - if it isn’t then the system time will be frozen and so the 5 second timer will never expire. The simplest way of doing that is to let the application run for a bit, then inspect the xTickCount variable in the debugger.
