ose wrote on Friday, May 18, 2018:
I have been trying to calculate the execution time of a task(led blinking) and i have followed the instructions here https://www.freertos.org/rtos-run-time-stats.html and also tried to understand the demo exmaples there and impliment it but i am using a different MCU(arduino uno) so i cant edit the demo for mine. I have also read how to use the vTaskGetRunTimeStats https://www.freertos.org/a00021.html#vTaskGetRunTimeStats and i have followed the instruction to the best of my undertstanding.
But i have been on this for the past three weeks and i have still not been able to get the task execution time showing in tabular form. I read some more and i think i will have to do some stuffs with ip address and some stuffs that seem to much for me as a beginner.
Please is there another way to get the task execution time or is there a demo for the Atmega328in regards calculating task execution time because i tried searching for but didnt see. Its possible i didnt look in the right place.
Any kind of suggestion will be great.
Below is my main.c++ and Freertosconfig.h, what i have done so far following the instructions and demo examples here https://www.freertos.org/rtos-run-time-stats.html
#include "FreeRTOS.h"
#include "task.h"
#include "queue.h"
#include "semphr.h"
#include
#include
#include
#include
#include
static void TaskBlinkMainLED(void* pvParameters);
int main()
xTaskCreate(TaskBlinkGreenLED, (const portCHAR*) "GreenLED", 100, NULL, 1, NULL);
xTaskCreate(TaskBlinkMainLED, (const portCHAR*) "ExtraLED", 100, NULL, 2, NULL);
vTaskStartScheduler();
for (;;)
return 0;
char bufptr1[150];
//set pin 5 of PORTB for output
DDRB |= _BV(DDB5);
TickType_t xLastWakeTime = xTaskGetTickCount();
for(int x = 0; x < 5 ; x++ ){
// LED on
PORTB |= _BV(PORTB5);
vTaskDelayUntil(&xLastWakeTime, (1000/ portTICK_PERIOD_MS));
// LED off
PORTB &= ~_BV(PORTB5);
vTaskDelayUntil(&xLastWakeTime, (1000 / portTICK_PERIOD_MS));
vTaskGetRunTimeStats(bufptr1);
vTaskDelete(NULL);
void vApplicationStackOverflowHook(TaskHandle_t xTask, portCHAR* pcTaskName)
// main LED on
DDRB |= _BV(DDB5);
// die
while (true)
_delay_ms(250);
_delay_ms(250);
void vConfigureTimerForRunTimeStats(void){
const unsigned long TCR_COUNT_RESET=2, CTCR_CTM_TIMER= 0x00, TCR_COUNT_ENABLE=0x01;
EECR|= 0x02UL;
TCCR1B = (TCCR1B & (~(0x3<<2))) | (0x01 << 2);
TCNT0=TCR_COUNT_RESET;
TCNT0=CTCR_CTM_TIMER;
CLKPR=(configCPU_CLOCK_HZ/10000UL) - 1UL;
TCNT0=TCR_COUNT_ENABLE;
#define configUSE_APPLICATION_TASK_TAG 1
#define configUSE_IDLE_HOOK 0
#define configUSE_TICK_HOOK 0
#define configCPU_CLOCK_HZ ( ( unsigned long ) 8000000 )
#define configTICK_RATE_HZ ( ( TickType_t ) 1000 )
#define configMAX_PRIORITIES ( 4 )
#define configMINIMAL_STACK_SIZE ( ( unsigned short ) 85 )
#define configTOTAL_HEAP_SIZE ( (size_t ) ( 1500 ) )
#define configMAX_TASK_NAME_LEN ( 8 )
#define configUSE_16_BIT_TICKS 1
#define configGENERATE_RUN_TIME_STATS 1
#define configUSE_STATS_FORMATTING_FUNCTIONS 1
#define configUSE_MUTEXES 1
#define traceTASK_SWITCHED_OUT() \
log_event( pxCurrentTCB, ulSwitchReason );
/* Co-routine definitions. */
#define configUSE_CO_ROUTINES 1
#define configMAX_CO_ROUTINE_PRIORITIES ( 2 )
#define INCLUDE_vTaskPrioritySet 0
#define INCLUDE_uxTaskPriorityGet 0
#define INCLUDE_vTaskDelete 1
#define INCLUDE_vTaskCleanUpResources 0
#define INCLUDE_vTaskSuspend 0
#define INCLUDE_vTaskDelayUntil 1
#define INCLUDE_vTaskDelay 1
extern void vConfigureTimerForRunTimeStats(void);
#define portCONFIGURE_TIMER_FOR_RUN_TIME_STATS() vConfigureTimerForRunTimeStats()
#define portGET_RUN_TIME_COUNTER_VALUE() TCNT0
