I am currently trying to build and link my assembler files within ESP32 vendor code within the Amazon FreeRTOS platform.
I have followed the instructions by espressif and in the .rst files within Amazon FreeRTOS. However when I try to compile I get the following error logs:
– Building for target esp32
CMake Error at vendors/espressif/esp-idf/components/ulp/component_ulp_common.cmake:55 (add_dependencies):
add_dependencies called with incorrect number of arguments
Call Stack (most recent call first):
vendors/espressif/boards/esp32/CMakeLists.txt:397 (include)
CMakeLists.txt:70 (include)
CMake Error at vendors/espressif/esp-idf/components/ulp/component_ulp_common.cmake:58 (target_add_binary_data):
target_add_binary_data Function invoked with incorrect arguments for
function named: target_add_binary_data
The relevant code in the CMakeLists.txt file is as follows and i Have highlighted the error line below:
set(ULP_APP_NAME ulp_${COMPONENT_NAME})
set(ULP_S_SOURCES “${board_dir}/application_code/ulp/ulp_adc.S”)
set(ULP_EXP_DEP_SRCS “${board_dir}/application_code/ulp_adc_example_main.c ${board_dir}/application_code/params.c”)
include(${esp_idf_dir}/components/ulp/component_ulp_common.cmake) # <------- this line is the issue
The section of code from the component_ulp_common.cmake file is as follows:
add_dependencies(${COMPONENT_TARGET} ${ULP_APP_NAME}_artifacts)
target_linker_script(${COMPONENT_TARGET} ${CMAKE_CURRENT_BINARY_DIR}/${ULP_APP_NAME}/${ULP_APP_NAME}.ld)
target_add_binary_data(${COMPONENT_TARGET} ${CMAKE_CURRENT_BINARY_DIR}/${ULP_APP_NAME}/${ULP_APP_NAME}.bin BINARY)
